Help me with an Equalizer extensions
I’ve recently started using Brave browser, and one thing I’m used to in Firefox was my Equalizer always being turned on. I installed five different Equalizer extensions for Brave, while searching for an extension, which would run in the background 24/7, but all of those extensions have to be manually enabled for each new tab. And it’s irritating.
I assume that the issue isn’t with the extensions, but with how Brave is built (some protection to stop extensions from having too much power). Is there something like a config page I can edit to bypass this limitation and just have my Equalizer extension run all the time in the background for all my windows and tabs?
  1. go to https://chromewebstore.google.com/search/equalizer
  2. for example, download “Advanced Audio Equalizer” by viiny.com
  3. open the Equalizer, and enable it
  4. observe that it only enables for the current tab
it appears that every Equalizer extension is limited to a single tab
once enabled, the Equalizer extension should stay enabled for every tab
100%
Ubuntu 24.04.2 LTS
Version 1.77.101 Chromium: 135.0.7049.115 (Official Build) (64-bit)
If this isn’t the right place to post this topic, please direct me to the correct category. Thank you.
@laylaleelai
Searching Brave Community, criteria: audio
-https://community.brave.app/search?q=audio%20in%3Atitle%20order%3Alatest
Searching Brave Community, criteria: equalizer
-https://community.brave.app/search?q=equalizer%20in%3Atitle%20order%3Alatest
Searching Brave Community, criteria: sound
-https://community.brave.app/search?q=sound%20in%3Atitle%20order%3Alatest
Using brave://flags in a Brave Browser New Window, search for:
  • audio
  • equalizer
  • sound
Using Brave Search online, found:
Searching for equalizer issues at GitHub > Brave Browser, found 1 issue from 2021:
Brave Support articles re using extensions:
