Help me, please? Polygon MATIC problem failed scam?
Whats happen?
What issue are you experiencing? Thanks
My Brave wallet is having this problem with Matic on the Polygon Mainnet. I can’t transfer within the BNB Ethereum Mainnet either, and I can’t receive tokens. What could have happened?
After 17/10 go to 0,0 after 5:00 am
It appears the balance is there, but the value is being displayed incorrectly.
This should not prevent you from sending or swapping your current balance.
Can you provide details on the issue you’re experiencing above? Are you receiving any type of error when attempting to transfer?
I cant swap or brigde
This may be an issue with how we’re identifying the decimal/comma.
If you try to bridge just 1 MATIC do you see a change in behavior?
Thanks for confirming
