Help me for website verification
Hi,
I’m trying to get my (Wordpress) site verified to no avail. Per http://giallopeperone.altervista.org/ instruction in the /r/BATProject Subreddit, I have manually created a .well-known subdirectory in the root folder, and uploaded the verification file there.
Please help me @Asad
@mariobros can you try the DNS record method? It’s easier IMHO and should works well.
DNS doesn’t work I just did it
Dns on altervista disabled. :disappointed_relieved:
Probably a permissions error with your hosting. Try DNS verification :slight_smile:
I’ve the some problem with my site hosted on altervista.org , rabbitigang.altervista.org. DNS doesn’t work . Any one has resolved ?
No, unsolved problem.
@ilBigo @mariobros AFAIK, you cannot verify your blog which is hosted on a subdomain of a blogging platform such as altervista, blogger/blogspot, etc because you have no direct access to the root directory or the DNS records.
There is of course a workaround for this but would cost you some $$. You can buy a custom domain for your blog. In this way you have full authority/access to modify the DNS records of your very own domain.
There are many domain registrars that offers cheap domain registration for different domain extensions. If you’re serious in blogging, I recommend going for a TLD extension such as .com, .net, and .org.
I am very hopeful tho that in the future Brave Rewards would offer a Javascript alternative for verification on blogs hosted on free subdomain of publishing/blogging platforms.
