Hardware acceleration is not working
I started having video playback issues recently dropping frames, etc. I rollback my gpu driver but the issues still persists. I tried changing flags but it still persists as well. When I go to brave://gpu this is the result.
Graphics Feature Status
  • Canvas: Software only, hardware acceleration unavailable
  • Direct Rendering Display Compositor: Disabled
  • Compositing: Software only. Hardware acceleration disabled
  • Multiple Raster Threads: Enabled
  • OpenGL: Disabled
  • Rasterization: Software only. Hardware acceleration disabled
  • Raw Draw: Disabled
  • Skia Graphite: Disabled
  • TreesInViz: Disabled
  • Video Decode: Software only. Hardware acceleration disabled
  • Video Encode: Software only. Hardware acceleration disabled
  • WebGL: Software only, hardware acceleration unavailable
  • WebGL2: Software only, hardware acceleration unavailable
  • WebGPU: Software only, hardware acceleration unavailable
  • WebNN: Software only, hardware acceleration unavailable
I tried with Vivaldi same result as well. But it in Edge it’s normal.
My current fix is to rename the .exe to brave1.exe and gpu status back to normal. It’s working ok with few hiccups.
My current running it on Windows 11 Home ARM, Snapdragon X elite, Lenovo Slim 7x
@adcd
Probably will help Brave Support, to know the specific Windows 11 Pro/Enterprise on Snapdragon X Elite device/laptop computer, because available drivers are a likely issue.
I have updated the post, it’s Lenovo Slim 7x. I did thought it was driver issue but I installed previous gpu driver and having the same issues.
@adcd
Re your “current fix is to rename the .exe to brave1.exe and gpu status back to normal” ← maybe indicates an installation/update issue? So . . .
IF you are a daring soul, you might go to: ‘https://github.com/brave/brave-browser/releases/tag/v1.85.118’ and get: ‘https://github.com/brave/brave-browser/releases/download/v1.85.118/brave-v1.85.118-win32-arm64.zip’
Expand that ...zip file. Temporarily move the existing brave.exe out of the Brave Browser installation “line of fire”:
"C:\Program Files\BraveSoftware\Brave-Browser\Application\brave.exe"
and park the brave.exe from the downloaded pkg, in that place - for test purposes. Other testing recommendations might suggest trying Brave Beta and/or Brave Nightly - but I have no experience with either.
AND/OR (probably less risk)
You might want to perform an Uninstall of Brave Browser, followed by a computer Restart, followed by an Install. Uninstall procedures are at:
The Brave Browser application brave.exe etc.:
‘Every time I open the browser it closes again directly - #20 by clifton’
The Brave Browser updater, BraveUpdate.exe:
‘Have to re-install Brave multiple times per day on Windows11 - #24 by mherrmann’
Of course, before all that, export bookmarks and back up passwords - do what you can, in order to preserve your data.
Looks it’s Qualcomm Control Panel causing the issues not the driver itself.
Uninstalling it won’t fix the issues, and according to the comments from Qualcomm rep you need to delete some registry but I can’t delete them. So I just did restore from a restore point.
@adcd did restore help? I actually was just trying to do some research, including checking with some AI to see if they could provide any helpful info. What I had come to so far was the info below that I was working on trying to fact check. But I’ll go ahead and copy/paste now instead.
This is a real and currently understood issue on Windows 11 ARM with Snapdragon X Elite, and it affects Chromium based browsers broadly. What you were told lines up with real world behavior seen on Lenovo Slim 7x systems.
The key points that are correct:
  • Chromium browsers are being forced into software rendering due to GPU blocklist or driver interaction
  • Edge works because Microsoft ships ARM specific overrides that upstream Chromium does not have
  • Renaming the executable bypasses driver application profiles
  • This is not caused by user configuration or hardware failure
On Lenovo Slim 7x systems, the Snapdragon or Adreno Control Panel utility has been repeatedly implicated in forcing incorrect GPU capability reporting. Uninstalling it has helped a number of users regain hardware acceleration immediately.
This is safe to try and reversible.
If you uninstall it and after reboot brave://gpu shows hardware acceleration enabled again, that confirms the control panel was injecting or modifying driver behavior.
Note: If the status is still “Software only,” the registry cleanup mentioned in that response is the next step. Qualcomm support has specifically suggested searching for and removing keys named SnapdragonControl or AdrenoControl to stop the driver from “remembering” the block.
As of late 2025/early 2026, Qualcomm released a critical update (v121.1) that explicitly addresses “app stability and performance” for Chromium browsers on ARM.
  • The Catch: Lenovo Vantage might not have this version yet.
  • Action: If your current driver version (check in Device Manager under Display Adapters) is lower than 31.0.121.1, you should consider the manual update from the Qualcomm Software Center. This version contains the specific fixes that make the “blocklist” unnecessary.
Microsoft uses a technology called Prism and specific “OS-level shims” for Edge. Essentially, Edge doesn’t ask the driver “Can I use hardware acceleration?” in the same way Brave does. It tells the OS “I am a system component, give me the GPU.” This is why Edge works perfectly while Brave is stuck in the 90s.
Forcing ANGLE backend
This can help, but results vary.
  • D3D11 is the safest option to try first
  • D3D11on12 can work but is more experimental on ARM
If hardware acceleration is already completely disabled, this flag alone may not override the blocklist, but it can help once the GPU is partially available again.
If Chromium has hard-coded your specific driver version as “unstable,” it will ignore your hardware even if it’s capable.
  • Go to brave://flags.
  • Search for Override software rendering list.
  • Set it to Enabled.
  • Relaunch. This tells Brave to ignore the internal blocklist and try to use the GPU anyway.
    This flag does work, but it is not risk free.
What it does:
  • Forces Chromium to ignore its internal GPU blacklist
Why to be careful:
  • The blacklist exists because crashes, visual corruption, or system hangs were observed
  • On ARM, this can cause tab crashes, black video, or full browser resets
It is acceptable for testing, but I would not recommend leaving it enabled long term unless it clearly stabilizes your setup.
Then I was also going to attack from other part like having you test on a new profile and all. But since happening on multiple browsers figured that wouldn’t make a difference. Definitely a lot of things to sort through sometimes. People would be shocked to see how much time I spend researching and testing things for answers sometimes.
Anyway, if the system restore helped then I guess can call it a day. Otherwise have some things mentioned there you can try.
Yes, restoring from restore point fix the issues, so it is the Snapdragon Control Panel causing the issues. Forgot to try whitelisting brave from the control panel before restoring.
Wow. And thanks for the details.
