hai am using ubuntu cosmic build (18.10) brave issue
when i run brawser in teminal it shows this error message
hai@Dell-Inspiron-3647:~$ brave-browser
[8574:8574:0225/203649.330086:ERROR:sandbox_linux.cc(364)] InitializeSandbox() called with multiple threads in process gpu-process.
[8538:8538:0225/203652.256013:ERROR:CONSOLE(1)] “Uncaught ReferenceError: brave_new_tab is not defined”, source: chrome://newtab/ (1)
[8538:8538:0225/203735.681041:ERROR:CONSOLE(1)] “Uncaught ReferenceError: brave_new_tab is not defined”, source: chrome://newtab/ (1)
how to resolve it or fix it thanks you…
For the gpu issue, turning off hardware acceleration in Settings --> Advanced --> System should do the trick.
For the error in new tab, I get the same thing when I open a new tab, but it doesn’t appear to affect the display of the default new tab display. I yield to those with stronger KungFu.
try it
$ brave-browser --disable-gpu
or it
$ brave-browser --ignore-gpu-blacklist
