Group Tabs do not minimize
Group tabs do not minimize, what is the point of the groups if they just take up more space…
I assumed you enable this via flags? If yes, then you can ask Chromium team for that too.
No, its there when you right click on the tab…
‘Add tab to group’
But it does nothing other then add a group that remains maximized the entire time. So it is kind of pointless…
I’m sorry. I’m not aware this is now enabled by default. :person_facepalming: But still, it’s inherited from Chromium. https://www.howtogeek.com/656707/how-to-enable-and-use-tab-groups-in-google-chrome/
I’m not sure if this is something that can/will be “fixed” by Brave team. Tagging @Mattches
Still worth a try.
P. S. https://github.com/brave/brave-browser/issues/7142
Try this one @cmont Add ability to collapse grouped tabs
Minimize = collapse!!! Thank you!
