(Not using a template as there have been some posts about graphical corruption in Chromium and AMD at least for two of their GPU’s officially pushed a fix on their side).
If you have been exhibiting issues with Chromium or Electron based applications, such as Brave, AMD has a fix on their side this time: https://www.amd.com/en/resources/support-articles/release-notes/rn-rad-win-26-1-1.html
If you are a user of an AMD GPU, even if it is not listed, it’s worth updating anyway. For example, I have an RX 7900 XT, and sometimes get a stray purple pixel on Discord, which is an Electron based application, so I will be doing this update myself as well.
As always, before filing bug reports over visual corruption, do remember to update your GPU drivers. If you have a laptop which has two GPU’s such as:
You want to ensure both GPU’s are up to date as well. For example, let’s say you have a laptop which has an AMD CPU/iGPU, but also has an Nvidia GPU, the LCD generally is wired directly to the iGPU, so even if Brave runs on the Nvidia, the iGPU’s driver becomes equally as important. (Recently I helped a few issues regarding laptops and graphical corruption with Nvidia GPU’s, it was never the Nvidia GPU at fault, but rather the Intel iGPU driver, because the LCD goes through that). If you have a desktop with dual GPU’s, as long as you plug the monitor into the discrete GPU, this isn’t an issue. (But you might as well keep all drivers up to date anyway, doesn’t hurt, only keep the API’s up to date).
