First print job from integrated PDF viewer does not reach CUPS on Linux (job silently lost, only subsequent prints succeed)
When printing a PDF from Brave on Linux (Debian 12), the first print attempt after opening the PDF fails silently — the print dialog appears, the printer is detected, and Brave reports “Printing completed”, but no job ever reaches CUPS. Also no print dialog is shown.
Subsequent print attempts from the same PDF usually succeed.
This issue has been reproducible since a few month and still occurs in Brave v141.1.83.112 (Chromium 130).
  • On the first print:
    • Brave shows “Printing completed via service” in brave://device-log
    • But the line shows:
      PrinterDebug[...] Starting printing via service for to `` for document X
      (→ printer name missing, no CUPS job created)
  • On the second print attempt from the same document:
    PrinterDebug[...] Starting printing via service for to DRUCK1 for document X
    (→ works correctly)
  • CUPS receives no job on the first attempt (journalctl -u cups -f remains quiet)
In brave://device-log:
PrinterDebug[11:22:06] Starting printing via service for to `` for document 59
PrinterEvent[11:22:10] Printing completed via service for document 59
(no CUPS job created)
Then:
PrinterDebug[11:22:16] Starting printing via service for to DRUCK1 for document 62
PrinterEvent[11:22:16] Printing completed via service for document 62
(job created successfully)
CUPS logs show no activity on the first attempt.
Environment:
  • Brave 1.83.112 (Chromium 130.0.6723.69)
  • Debian 12 (bookworm) - LMDE 6 (faye)
  • CUPS 2.4.2
  • Printing via network printer (IPP) through a local ImplicitClass queue
  • Brave launched with these flags:
    --disable-features=UseCupsPrintBackend,PrintJobRouting,PrintBackendService \
    --enable-features=PrintPreviewUseGdiTextRendering,UseSystemPrintDialog \
    --disable-print-preview
  • Printer is always detected correctly and shown as DRUCK1 in device log.
  • The issue occurs both with and without these flags.
