Feature Request: “Pin to right side” for bookmark folders
I would like to suggest a new feature for the bookmarks bar: the ability to pin bookmark folders to the right side of the bookmarks bar.
Currently, all bookmark folders are placed together from left to right. I would like to keep frequently used bookmarks and folders on the left, while moving less frequently used folders, such as “All bookmarks”, archives, or old folders, to the far right.
For example, I would like to have:
[YouTube] [Twitch] [Kick] [Gmail] [Genius] [
Twitch] [
AI] | [
Archive] [
Old] [
Other] [All bookmarks]
The “|” would visually separate the main bookmarks from the folders pinned to the right.
Steps to Reproduce:
- Open the bookmarks bar.
- Create or select a bookmark folder.
- Right-click the folder.
- Select a new option called “Pin to right side”.
Actual Result:
There is currently no way to pin a bookmark folder to the right side of the bookmarks bar.
All folders remain part of the same bookmark bar area and have to be manually arranged.
A “Pin to right side” option would move the selected bookmark folder to a dedicated area on the far right side of the bookmarks bar.
Pinned folders would remain on the right even when new bookmarks or folders are added to the main area.
For example:
Normal bookmarks:
Twitch] [
AI]
Pinned to the right:
Twitch] [
AI] | [
Archive] [
Old] [All bookmarks]
Users should also be able to drag and reorder folders within the pinned right-side area.
There could also be an “Unpin from right side” option in the context menu to return a folder to the normal bookmark area.
Always. This is currently a missing feature rather than a bug.
Operating System and Brave Version:
Windows 11
Brave Browser 1.94.121
This feature would make the bookmarks bar much easier to organize.
The idea is to have two separate areas:
- Left side: frequently used bookmarks and folders.
- Right side: less frequently used folders, archives, old folders, and “All bookmarks”.
This would be especially useful for users who have many bookmark folders but only use a few of them regularly.
The main goal is not to hide or delete unused folders, but simply to keep them separated from the frequently used bookmarks.
A “Pin to right side” option would provide a simple and intuitive way to achieve this.
