Easy Auto refresh extension doesn't work anymore with refresh times over 59 seconds
The extension Easy Auto Refresh (by ksoft) no longer works with refresh times above 59 seconds
  1. Open a website
  2. Click on the extension button in the top toolbar
  3. Set a time in seconds
  4. Click Start
**Expected result:**Web page should be refreshed after the selected time
1.91.175
This extension has worked for several years in Brave. The person behind the extension told me it has to do with Google changing the browser alarms API in Chrome, where 60 seconds is now a separation between still working (<60) or no longer working (>59). What he told me matches exactly what I see here.
I have tried it also in Chrome, Edge and Firefox and in all those browsers it works as it has always worked. Only in Brave (my favorite) it does not work at the moment. Can I say that when it works in Chrome (again?) means Google has repaired it and this has not yet been done in Brave or am I totally wrong here?
Can you try an alternative like this: https://chromewebstore.google.com/detail/refresh-page-auto-reload/egikkennjmdkmenllfmbigafjhicmeep
Thanks for your answer. I must say it is not the solution I would like to have:
An extension has worked as long as I’m using it until now. It did not change, it stil runs on other browsers, only not anymore on Brave. Now I should get a different extension to solve the problem. This seems to me the world upside down.
Something in Brave changed, why and how is unclear to me but my view on the matter is that Brave should change something to make the extension, and maybe even others as well, work again.
I do hope you can agree to that.
I am not aware of any changes that Brave has made to extension packages, other than that Brave still supports MV2, unlike the majority of Chromium browsers. It’s quite peculiar that other browsers don’t have this issue…
Sorry to see that your old refresh extension doesn’t work for you!
If you found a solution, please mark the post you believed helped address your issue as solved.
I am a user, not a Brave employee.
