DuckDuckGo Settings Registration Persistence Settings
Description of the issue: Discovered following testing. The duckduckgo “search assist” and “hide ai-generated images” settings do persist if you set them up. However there is a subtle way to access them. Those default settings only affect searches entered into the address bar (URL Bar). If however you enter the search into the “Ask Brave Search” homescreen box they are ignored. In addition one loses the ability to manualy change the search parameter such as; location, time, safety. Looks like its been designed that way!
Brave Version :Brave 1.85.118 (Official Build) (arm64)
Operating System: Tried this on Win11 and on MacOS
My consolidated notes re Brave Search and Search Engine Operators (“SEO”):
‘Brave search exclude terms not excluded - #8 by 289wk’
The Brave Search Field:
