Dragging window causes extreme laggs
Greetings, suddenly when I want to drag existing or new window, brave laggs very badly. I thought maybe I need to update the app, but there is no new update available (Brave 1.90.121). Also tried to turn on and off HW acceleration but it didn’t help. Tried to reboot PC multiple times, made sure my NVIDIA drivers are up to date but it still laggs.
Any idea what can cause the issue and how to fix it?
  1. Open new tab
  2. move to a different monitor
  3. laggs
Brave Version( check About Brave): 1.90.121
**Additional Information: **
Platform- Windows 11
CPU- ADM Ryzen 9 5900X
GPU- NVIDIA GForce RTX 3080
RAM- 32 GB
it’s not pc issue, tried Firefox and it worked fine so idk
@enaxtry
Create a new Brave Browser user profile (Menu --> More tools --> Add profile) for testing. When creating this new Brave Browser user profile, try to keep it simple:
  • Do not import anything.
  • Do not add any extensions.
Suggest that after you create that new user profile, Exit / Quit everything and restart the computer … and then choose the new user profile for testing.
This also just started happening to me the last two days, zero changes to my hardware or OS, no newly installed software.
Windows 11, 5900X, RTX 3090, 64GB ram.
Brave 1.90.121
Started happening for me on both my home and work PCs.
Both have Intel Core i9, RTX 30XX, 64gb ram.
One is Win10 and the other is Win11.
Both using latest Brave 1.90.121.
