Documentation Update To Correct Error In Power Savings FAQ
Hi,
On This Page: https://support.brave.app/hc/en-us/articles/13383683902733-How-do-I-use-the-Memory-and-Energy-Saver-features-in-Brave
You have this text:
How do I use the Energy Saver Feature?
To extend your device’s battery, Brave reduces its image capture rate and other background tasks.
When Energy Saver is on, it works automatically whenever your device is unplugged, or when your battery is low. Energy Saver doesn’t turn on when your device is plugged in.
To enable or disable Energy Saver:
  1. Launch Brave
  2. Navigate to Menu --> Settings --> System --> Power
  3. Toggle the Energy Saver option on/off:
The setting referenced isn’t in Brave
Brave Version : Brave 1.81.135 (Official Build) (64-bit)
Chromium: 139.0.7258.127
HTH
Shane
