Device recognition setting reset to default
Geräteerkennung (Device recognition) setting reset to default.
  1. start brave
  2. change setting Geräteerkennung (Device recognition)
  3. restart brave
Brave should show the changed value.
Brave 0.68.132 Chromium: 76.0.3809.132 (Offizieller Build) (32-Bit)
Überarbeitung fd1acc410994a7a68ac25bc77513d443f3130860-refs/branch-heads/3809@{#1035}
Betriebssystem Windows 10 OS Version 1809 (Build 17763.195)
Did it happens only for “Device recognition”, @Johann ? How about other shield settings? Did you change the global shield settings or per-site shield settings (via Brave icon at URL bar)?
It happens only for ‘Device recognition’. I have change the global shield settings.
I don’t use per-site shield settings.
@Johann,
Have you cleared your browsing data and/or do you have any data to be cleared on exit (Settings --> History --> Clear Browsing Data --> [On Exit])?
On Exit i clear all data.
@Johann,
I believe that’s the problem then – we have an open issue right now wherein Shields settings are wiped/reset alongside browsing data. We’re working to decouple these data so that it can be wiped without effecting Shields settings:
