Determining switch position in “settings”
In “settings” there are several switches that can be turned on or off. How do I know which position they are in? Is it to the left or right to turn on?
usually they’re colored… on is orange, off is grey…
Edit: for the color blind… on is to the right (->), off to the left (<-)…
Thank you, Megaspaz.
