Do you guys have any plans for improving Brave Dark Mode ? For example ;
@toweros can you elaborate more?
Also you should try and search “website dark mode” on the internet and you’ll see some examples.
Ah got it. Thanks for the screenshots @toweros.
I’m not sure if this met your needs, but you can
- type chrome://flags
- in the search bar, search for “dark”
- enable “Android web contents dark mode”
- relaunch Brave
Please note, that Brave not “officially” support this option yet. It’s inherited from Chromium. So you may encounter some bug/s.
I would like a black mode for the UI, looks better on oled screens.
