Cursor offset in Nextcloud
Cursor offset in Nextcloud. So when I try to work in a document or sheet, my cursor is too high & too far left, which makes navigation nearly impossible.
https://nextcloud.hku.nl/apps/onlyoffice/9025543?filePath=%2FDocuments%20Astrid%2Ftest_cursor.docx
(but this is my test-example file, behind my password of course)
**Did the issue present with default Shields settings? YES
Does the site function as expected when Shields are turned off? NO
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): Not that I know of
Does the site work as expected when using Chrome? YES
Version 1.75.178 Chromium: 133.0.6943.98 (Official Build) (arm64)
sadly, not solved by the update I just did…
anybody? this is still a problem…
