In Google Sheets, I am unable to “Paste Special” (i.e. paste without formatting) by using the shortcut Ctrl + Shift + V.
There are a couple caveats to this – for when Ctrl + Shift + V will work:
- It will paste special if my cursor is actually inside the cell (i.e. by double clicking or pressing F2).
- It will paste special if the I copied other cells from within that spreadsheet.
So, basically, the issue is when I copy data from outside the spreadsheet. So let’s say I copy “25” from any other source (e.g. Email client, Word Document, notepad, whatever), then I go into my Google Sheet and press Ctrl + Shift + V while the destination cell is highlighted, nothing will happen.
It works fine in chrome. In Brave, I made sure there’s no extension shortcuts mapped to the Ctrl + Shift + V that might be overriding it. I also tried in incognito with no extensions on.
I’m on MacOS Sierra v10.12.6 (16G29) (but also tested on Windows same issue) and I am using Brave Version 1.5.123 Chromium: 80.0.3987.163 (Official Build) (64-bit)
TOPIC FIRST OPENED HERE (NOT RESOLVED):
https://community.brave.app/t/ctrl-shift-v-doesnt-work-in-google-sheets-for-paste-special/61169/5
