Crypto Wallet wont load tokens
Hi all,
When I login to my crypto wallet with my password on knightly and official builds, the wallet won’t load the tokens after the latest update.
The “Loading tokens” message sits there forever.
Brave_Crypto_Wallet_Error
I have 5k JSE tokens in there after adding a custom token, which worked, then I sent my JSE to it and it was fine. Then after this latest update, the tokens won’t load anymore.
Windows 10 Pro / Build 14393 - x64
Brave Official and Knightly latest builds.
Thanks for any help guys <3
PSS. Also for the past 2 updates, brave official has an error message when clicking on the brave rewards icon in the bar.
" Uh oh. Your wallet is unreachable.
No worries. This can happen for a variety of security reasons. Reconnecting your wallet will solve this issue."
I fixed it by going to etherscan, putting in my ether address, then clicking on token drop down box, and selecting JSE. Then I went back to the wallet and all the tokens showed up…Phew! :slight_smile:
