@vcx.designs when I sent you DM earlier you should have a notification. Just like where I tagged you just now, you should see notification appear. Click on it and then it will open that message.
Going to mail takes people to something like https://community.brave.app/u/saoiray/messages
Put your name in place of mine and it should load. So would be something like:
https://community.brave.app/u/vcx.designs/messages should take you to your inbox.
Yeah I found it, thanks!
Only issue now is I canāt upload attachments because my account is new, so I will need to find a different way to upload the file securely unless itās enabled.
Doesnāt look to be the case. Your Trust Level is as Basic User which is all you need as far as I remember. But you do have to make sure itās a .txt form or whatever.
In any case, Iām just another user. While Iām able to do things like initiate DM or lock topics, I donāt have ability to change trust levels or anything. So big thing just will be for you to follow up with Mattches and Steeven, who both are from Brave.
Ah ok, thanks for getting me this far, itās been a huge help and hopefully those two can help me and others out with this issue!
