Crash reports do not seem to be sent automatically despite active setting
Description of the issue: Crash reports do not seem to be sent automatically despite active setting
  1. Check whether the setting under brave://settings/ is active, that crash reports and usage statistics are active
  2. Cause a crash
  3. brave://crashes/ call. Here you can send the report manually, apparently this didn’t happen automatically.
Expected result: The report should be sent automatically
Reproduces how often: Unknown
Operating System and Brave Version: Windows 10 version 1809, Brave: Version 0.62.51
@MediaBird Thanks for reporting. Issue is already fixed in Brave beta, crash reports are enabled automatically in settings. Fix will be available in upcoming release version. If you want test now please download brave beta.
Thanks!
