Briefly describe your issue:
Same country, different ISP. Ads enabled in Home, but in Work says country not supported.
macOS [Versión 1.34.80 Chromium: 97.0.4692.71 (Build oficial) (x86_64)]
No
N/A
N/A
Are you using a VPN? (yes/no)
no
yes
N/A
N/A
I would like to submit mi static IP for the inclussion in my country, or check by is that Brave does not detect my IP as my country.
