Copying to clipboard in various apps does not seem to work.
I have selected “sites can ask to see text and images on your clipboard”
If I go to site-specific settings, under clipboard, it says “Blocked to protect your privacy”, which (as you saw above) is not what I my configuration specifies.
The “block” dropdown in site-specific settings is disabled as well, so it appears there is currently no way to enable the clipboard, at all.
- Click on “copy” on a web site that lets you copy to clipboard.
- Paste in another app - observe that nothing is in the clipboard.
It should copy to clipboard.
Brave 1.80.122 (Official Build) (64-bit)
Chromium: 138.0.7204.157
Additional Information
Using Windows 11 with all recent updates.
