Connection of Wallet on Android
I just connected my brave wallet on my laptop into brave rewards for the first time. I can’t connect any wallet because of my region.
So I am so happy to see a notif that saying you can connect a wallet using your brave wallet on Sol network.
But my issue, there is no option for my android device to connect my brave wallet on brave rewards. I just saw an Upload wallet which is not accessible for my region. I hope you help me.
My device is a Huawei android 13
Thanks!
Saoiray just reply this to other post. Thanks!
it’s because it is still by invite only at the moment. It’s a slow gradual rollout. You may want to read one of the more recent updates that I provided at PSA: Current and upcoming changes to Rewards and Creators - #24 by Saoiray
Since it is still a little random it would be possible that one of your device profiles would be able to connect while the other doesn’t. But if you keep checking ever so often it should eventually pop up.
