It’s happened to a few people. The devs are looking into it.
Righto, thanks. It’s always good to hear one isn’t unique in these regards.
I went ahead and bit the bullet today to set up a Gemini account for that browser, one less thing to think about and besides, I may need additional “slots” in the future in any case. Not that improving the slot management shouldn’t be a priority for a future fix mind you!
Thanks for all your help.
Regards,
Victor
Well, i am sure they go by wallet id or something. And every device has a different one.
New windows install, new wallet id.
And there don’t seem to be a workaround. Like backing up all brave files and pasted them back in after fresh installs if windows for example.
But yes. This needs a rapid solution. I only use 1 PC and 1 phone with brave. And the limit within a year by just setting up fresh windows installs twice.
4 connections is just horrible. Especially when old connections that are not active will just linger forever without a way to clean them up.
@VictorZ Take a look at this thread, especially the instructions from Mattches:
Thanks for the thread link. I’ll look into that however since I’ve just gone ahead and verified that browser with Gemini at this point, I’m not sure it’ll be of much help / use. Gemini verification / linking went through smoothly … once Gemini set up completed fully which took a few hours and appears to be critical since it didn’t work until that point.
VictorZ
Until you hit the device limit again in the future
