Clipboard for screenshots does not work. Even if I turn on access to the clipboard in the site’s settings, nothing will change. This problem haunts me on all versions of Brave, including the portable.
- Take a screenshot with a print screen
- Try to insert and send it to the social network dialog
- Try to insert it into the power point
Expected result: I can insert a screenshot into the dialogue of a social network or program on my PC
Brave Version( check About Brave): Version 1.5.115 Chromium: 80.0.3987.149 (Official Build) (64-bit)
OS - windows 10 home
