clickable links have a black border box when click
as title. this happened today. the problem does not occur in Chrome/Edge. I tried to install a fresh copy on a newly installed windows PC, but the problem persist. This only happens on some websites. (not before)
as image shown, clicking or right clicking on Events link, a box appeared.
Do you see the same in a Private Window for this site?
Do you have any accessibility settings enabled?
It happened also Private window. Accessibility is normal. I know the reason is the website concerned has a css rule: a:focus {
outline: 5px auto -webkit-focus-ring-color;
outline-offset: -2px; } but the rule has always been there. Before I updated Brave, the black box never displayed (it also won’t display in Chrome/Edge). Just after the recent update, the black box appears.
PS. I just noticed the latest version of Chrome also has this problem. So I think the browser is just more proactive to render the css.
Since I have access to the website myself, I just added
:focus:not(:focus-visible) {
outline: none;
box-shadow: none;
The problem is solved.
