Click and Dragging Bookmarks
Just a small suggestion, but with the bookmarks in the browser, could we have the ability to select multiple bookmarks/folders by clicking and dragging to then move them into other spaces or locations? I don’t want to just move one at a time, and it’s a small fix but it’d be really convenient for reorganizing bookmarks.
@blunkerpool would you believe me if I said this already exists? But you would need to go to your bookmarks manager, not from the bookmarks bar. If you go to brave://bookmarks/ then you will see the list of bookmarks. Using Windows as an example, you would hold Ctrl and left click to select which bookmarks you want and it will highlight.
If you click one, hold Shift, and then click another, it will highlight everything in between.
Whenever they are selected, you can then drag them to other folders or so.
Bookmarks bulk
Thank you, this was helpful!
