When using Brave wallet on iOS and Wagmi’s `useAccount`, the chainId is always set to 0.
The underlying problem seems to be that there is something wrong with the connector; it also says there is no function `f.connector.getChainId` when using useSignMessage
I’ve tried using the Brave connector and the Injected connector, same result.
Strangely, Wagmi’s useChainId reports the correct chain.
Is the issue occurring on a specific network? No
What operating system are you using? iOS
Brave Version (check About Brave): 1.82.1
Additional Information: Works fine with MacOS extension
I also see this error in my logs WKWebView API client did not respond to this postMessage
