Can't inspect remote device from devtools
When i try to use the inspector of remote device from developer tools it doesn’t work and the inspect window show a blank white page although i can do that on chrome and chromium.
  1. Connect your mobile device (that has aversion of app you need to debug) to the computer.
  2. Open the brave developer tools and select remote devices then your device will appear on the list, click inspect to open the inspector and you will the that the inspector window is blank and not working.
The remote devices inspector not work and open a black window.
The remote devices inspector should open correctly and let me inspect and debug the application.
Brave Version 0.62.51 Chromium: 73.0.3683.103 (Official Build) (64-bit)
Operating system is Linux Pop!_OS (Ubuntu based distro)
I am able to reproduce this on Windows 10.
I’m also unable to inspect remote devices. But Google Chrome works on the same machine.
@zekry @noman115pk @doublev per https://github.com/brave/brave-browser/issues/1736 it seems that remote debugging is disabled.
