Error: Region not supported
Unfortunately, your Brave Rewards cannot be verified because your region is not supported for Brave Rewards verification at this time.
This error occurs when you try verifying rewards in a region which isn’t supported for Verification at this moment. You can check if you are in one on this page →
If your region is not listed above then, you’ll have to wait patiently till Brave allows your region to verify.
Get more updates at PSA Unsupported Regions
