Can not upgrade with Homebrew
For a few days now upgrading Brave with Homebrew fails.
Error: brave-browser: Download failed on Cask ‘brave-browser’ with message: Download failed: https://updates-cdn.bravesoftware.com/sparkle/Brave-Browser/stable-arm64/188.134/Brave-Browser-arm64.dmg
Even after disabling VPN, filters and connecting on a private Wifi. It looks like updates-cdn.bravesoftware.com is refusing my connection somehow.
  1. brew update
  2. brew upgrade --cask brave-browser
An upgraded version of Brave, installed on my laptop.
Update failed (error: 11)
Error details:
An error occurred in retrieving update information. Please try again later.
Learn more
Brave 1.88.132 (Official Build) (arm64)
Chromium: 146.0.7680.80
  • There really is an error message in the dialog ‘About Brave’.
  • The full console output:
$ brew upgrade --cask brave-browser
==> Fetching downloads for: brave-browser
✘ Cask brave-browser (1.88.134.0)
Error: Download failed on Cask ‘brave-browser’ with message: Download failed: https://updates-cdn.bravesoftware.com/sparkle/Brave-Browser/stable-arm64/188.134/Brave-Browser-arm64.dmg
==> Upgrading 1 outdated package:
brave-browser 1.88.132.0 → 1.88.134.0
==> Upgrading brave-browser
==> Purging files for version 1.88.134.0 of Cask brave-browser
Maybe it’s a DNS issue ?
$ dig updates-cdn.bravesoftware.com
; <<>> DiG 9.10.6 <<>> updates-cdn.bravesoftware.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 1369
;; flags: qr rd ra; QUERY: 1, ANSWER: 6, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1410
;; QUESTION SECTION:
;updates-cdn.bravesoftware.com. IN A
;; ANSWER SECTION:
updates-cdn.bravesoftware.com. 4 IN A 146.112.53.140
updates-cdn.bravesoftware.com. 4 IN A 146.112.53.170
updates-cdn.bravesoftware.com. 4 IN A 146.112.53.20
updates-cdn.bravesoftware.com. 4 IN A 146.112.53.143
updates-cdn.bravesoftware.com. 4 IN A 146.112.53.40
updates-cdn.bravesoftware.com. 4 IN A 146.112.253.228
;; Query time: 23 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Tue Mar 24 10:10:17 CET 2026
;; MSG SIZE rcvd: 154
@JG9486
Testing, I used iPhone and Safari to download:
‘https://updates-cdn.bravesoftware.com/sparkle/Brave-Browser/stable-arm64/188.134/Brave-Browser-arm64.dmg’
… with no problems.
Brave Browser Changelog:
‘https://github.com/brave/brave-browser/blob/master/CHANGELOG_DESKTOP.md’
Clicked on latest version number 1.88.136 and scrolled down to:
https://github.com/brave/brave-browser/releases/download/v1.88.136/Brave-Browser-arm64.dmg
  • in case that interests you.
That probably means Cisco found another way to block Brave from being installed. Cisco Umbrella most likely. The strange thing is that this used to work.
There is prior history of Cisco considering Brave a nuisance because it is capable of using Tor. When then not simply block Tor instead ?
@JG9486
Copy the link that you provided, and paste it into the URL address field of your Internet browser. Go. Get the download.
But you might modify/test the version.
IF you can get the .dmg file, then your issue is likely with Homebrew … and/or something MacOS.
Just had confirmation this is the Cisco Umbrella proxy blocking the access. I’ll try to ask local IT to whitelist it.
Both Cisco Umbrella and Palo Alto Cortex were blocking the access. Which is fixed now. I suppose it’s a renewed attempt to block Brave because it allows Tor sessions. Which everybody knows is evil ! Not. :grinning_face: It’s a pity even those big compagnies are still that retrograde.
I’ll close this ticket.
