Bug: White flash in the Construct 3 engine popup
Steps to reproduce the bug:
1 - Go to the Construct 3 engine website: https://editor.construct.net/
2 - Click on the “NEW” button.
3 - Click on the “Create” button to create an empty project.
4 - Click on the “Preview layout” button (play symbol).
Result: A popup with a white flash will open.
OS: Windows 10 PRO 22H2
Brave version: 1.85.118
Do you by chance see the white flash when opening a new tab as well? Another user saw something similar and had an Nvidia GPU. I have a Radeon now and have no white flash, but do remember having one when I had a 1080 Ti before I upgraded.
I wonder if this is related since the flash happens the moment the window opens (which is similar to opening a new tab).
I saw the same flash in Chrome also, seems the way the site its designed?
My video card is an Intel HD Graphics, and the white flash also occurs in the new tab. I have the impression that the white flash is caused by the “about:blank” page that most websites use before loading the page. I tested it in the Opera GX browser and the white flash does not occur, perhaps because the Opera browser uses a type of filter that darkens about:blank, which is the likely cause of the white flash.
