Brave will not load following full system update.
Executing brave results in cursor showing the application is loading, then stops.
System Monitor shows the application start-up, then close.
Attempting to load from terminal reveals the following:
[64107:64107:0326/220152.768083:ERROR:base/memory/shared_memory_switch.cc:289] Failed global descriptor lookup: 7
[0326/220152.844310:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.844609:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.844735:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.850198:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.851033:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.851245:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.851317:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[0326/220152.851953:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0326/220152.851968:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0326/220152.858747:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0326/220152.858758:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0326/220152.858789:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[0326/220152.858799:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
WARNING: radv is not a conformant Vulkan implementation, testing use only.
fish: Job 1, 'brave' terminated by signal SIGBUS (Misaligned address error)
Tried running with various flags, as recommended by google’s AI:
--no-sandbox
--ozone-platform=x11
--ozone-platform=wayland --disable-features=WaylandWpColorManagerV1
--disable-gpu --no-sandbox
None of these flags had any effect.
Removed profile folder and was able to successfully start brave, however brave sync seems to not be able to retrieve any data.
Narrowed issue to History file in .config/BraveSoftware/Brave-Browser/Default/. Removing it caused brave to restart with previously open tabs, but no extensions or bookmarks would show up.
Re-adding the History file causes Brave to fail loading again.
Really want to get back my personal data.
Not sure what to do from here.
Assistance troubleshooting would be greatly appreciated.
System
OS: CachyOS x86_64
Kernel: Linux 6.19.10-1-cachyos
DE: KDE Plasma 6.6.3
WM: KWin (Wayland)
CPU: Intel(R) Core™ i7-6700K (8) @ 4.20 GHz
GPU: AMD Radeon RX 9070 XT
Memory: 15.55 GiB
Brave Info
Repository: cachyos
Package Name: Brave-bin
Version: 1:1.88.136-1
