Brave won't launch on Linux mint DE4 and external monitor
When connected an external monitor to my Linux mint DE4 computer, brave just hangs, works as soons as I disconnect the monitor. Tried firefox and that works, and all other application just Brave that does’t launch
Install LMDE4 install brave connect external monitor, my case 4k NEC
Brave hangs and needs to be force quit
brave to launch
everytime I connect external monitor, I have tried more then a 4k and same result
Linux mint Debian version 4
latest available version, I done a couple of updates of brave and still same result
Hello @krspa
could you disable hardware accerlation brave://settings/system and see it get fixed or not
Hi
thanks works like a sharm.
thanks, do I close the issue?
glad to know that it worked and you welcome and you just marked it as solved so the community admin will close it :slight_smile:
