Brave wallet not showing sol balance
Same issue still. No SOL balance is showing.
Same issue here. Sol Dapps like Jupiter can see my balances, but I cannot verify transactions and my Brave wallet does not show anything. I know Solana was down yesterday but they got it up like in 2-3 hours and in my other Browser Phantom has been working fine since that. And now I need my funds in my Brave wallet so can somebogy work on the solution, pls?
I have this issue also, moved my seed phrase to phantom and worked fine. May be a RPC issue.
Did the same thing, imported my wallet to phantom and my balance was there, worked fine.
Sorry for the trouble everyone. It’s a node provider issue and should be resolved very shortly. Thank you!
Appreciate your answer, thank you for keeping us informed <3
Evan, I still do not have access to my sol account in the Brave wallet. Are RPC’s still not working? Could this be another problem? Please advise its been 24 hours.
thanks for the update.
Iowner is your account back to normal yet? mine is still not working.
Hi Zerni, could you assist me with how to move my seed phrase to another wallet. I am experiencing the same issue as you.
I think just get the phantom extension and input your brave seed phrase I havent tried yet
I moved my account of brave. super disappointed with the service and customer support. I have been a long time friend of Brave but hard to support a company that offers no support. Just incredibly disappointed. It seems to me it is not an issue on the solana side when I could view my accounts in moments on phantom once i moved it over. Please explain to me that i am wrong because at this moment it seems Brave responded to clients without properly identifying the issue and then offering very little guidance based off of the wrong information…
Install a wallet you trust and import seed phrase. You can copy it by opening the wallet tab >clicking on accounts>then top right should be 3 little dots select backup.
But your coins are yours as long as you own your words wait until you get more experience in crypto you don’t want to lose anything. If you don’t want to wait be sure to verify all downloads.
Did you use phanton extension? I want to do this but im scared. Is it that easy just import that backup seed into phantom?
Hello! This should now be resolved everyone. Please let me know if you’re still running into trouble.
working properly again. thanks. :slight_smile:
See my Sol tokens again in my wallet, problem solved!
I’m very sorry for the inconvenience this issue has caused you. We’ve switch our RPC provider over to a new solution due to the extended outage we experienced. If you’re running on an older version of Brave Browser I’d encourage you to update to the latest which will reflect the new change.
All good! Thank you!
I used the extension and :heart_eyes: it! Easiest thing ever and felt very empowering!
