Brave video streaming: sound stuttering & become distorted sound effect
I’m watching a video on a drama streaming site. When I play it, the video seek bar reaches a certain point (e.g., 0:02), and the sound starts stuttering and turning into a distorted, robotic effect, making it completely unlistenable.
Yes
No. I tried to launch as new private window without any extensions & turned off the shield. The issue still happened.
No, I tried to launch as new private window without any extensions & turned off the shield. The issue still happened.
Yes, both edge & chrome are working. Only happened in Brave.
v1.8.0.124 (64bit)
Chromium: 138.07204.168
Alternatives to resolve it but none of them working
  1. uninstall nvidia gpu driver with DDU. Then reinstall driver with clean start.
  2. uninstall and reinstall realtek sound driver.
  3. reset brave browser with no extension at all, even uninstall & reinstall again.
  4. Turn off brave graphic acceleration when available option under settings section.
@cutesniper
Search the Brave Community for tips . . . using terms:
video, D3D11, Metal, NVIDIA, Angle Graphics, OpenGL, Vulkan, WebGL, Skia Graphite (skia-graphite)
And search, using those terms, in a BB New Window at brave://flags - where you may experiment.
