Brave V1.21.73 does not work with mooltipass extention anymore
The extention for my offline password safe (Mooltipass https://www.themooltipass.com/) is not working anymore with the newest versions of Brave. Erros message is “Mooltipass Application is Missing!”.
For better understanding, Mooltipass is a hardware password safe. The release of user/password combinations must be done physically on the device.
To automatically fillout login fields or to store new credentials you need a browser extention. This does not connect directly to the USB device. Instead it connects to a userspace application via encrypted websocket on localhost. This application sends login requests or new credentials to the device. The device transfers the credentials to the application and the application sends it to the extention. The extention then fills in the fields and executes a login. For new credentials the whole thing in the other direction.
  1. Install the Moolticute extention and the client application: https://www.themooltipass.com/setup/
  2. Connect a Moolipass (if available)
  3. Unlock the device mooltipass device.
  4. The icon of the moolipass extention sould be white NOT red.
Connection between the extention an the client application possible. Extention icon becomes transparent.
allways
Linux Mint 20.1, Brave V1.21.73
Worked till last update.
@Hovy,
Thank you for reporting this. We’ve opened the following to capture data on this issue:
I’ve added your report there as a +1 on your behalf for the developers to review.
Thanks for the fast help, guess some password solutions are affected by this.
