Am totally bugged about the ram usage of brave in my Macbook Air 2020 (M1)
After 5-6 tabs the ram usage literally eats nearly 2 gigs like straight up, now my laptop config has 8 gigs of ram and with brave it always stays at 5.5-6.5 gigs all the time (max 10 tabs open) and that basically makes it harder to use other applications without closing brave and i cant figure out why do all the extensions use so much ram also including the brave helpers which also seem to consume a lot of ram, now I am aware that some of the helpers are dedicated for the extensions but the extension itself is smaller in size than the ram it uses up. I have got 4 extensions installed.
Brave Version: [Version 1.31.88 Chromium: 95.0.4638.69 (Official Build) (arm64)
