Hi,
I think that Brave have a too much RAM usage.
How can I reduce this ?
With 21 tabs opened :
Hi,
@Ghosteuh,
Extensions – both built-in and 3rd party – are playing a factor here as well. It also depends on the tabs themselves and what site(s) are open in them. A lot could be at play here – how much memory are Chrome/FF using comparatively?
With Chrome about 1Go less (the same tabs are open, Brave count 32 threads against 28 in Chrome) :
I don’t re test with these tabs but the same.
P.S : You see, Valorant take less RAM than Brave
EDIT 2 : when I relaunch the browser that’s insane
(i Have a Ryzen 2600X so I don’t understand how it’s possible that Brave takes 60% of UC).
And I just have 2 extensions
I’ve used Microsoft Edge a lot since it was Chromium based. From my rudimental but fair testing, Brave uses significantly more CPU and RAM than Edge also.
Without getting into the ins and outs, I think Microsoft have generally done a good job with Edge on desktop and mobile so far.
I’m looking at Brave as a working progress, I want to like it, but it fails in a few key areas for me at the moment. Looking forward to see how it progresses.
@Ghosteuh,
Thank you for the detailed report. I’m going to reach out to some devs to see if maybe we changed something that’s producing the additional resource usage. Also – did you try disabling HWA to test and see if that makes any difference?
No significative difference without hardware acceleration.
Well, it’s not so bad, just a little higher Chrome so that’s ok.
Also, I sent you a DM about rewards, have you seen this ?
I assume you’re looking at Brave because you don’t want to be tracked and monitored. If you’re looking at Edge as well then maybe I should assume you do want to be tracked and monitored…
