Issue
Brave’s native translation feature is being blocked on multiple websites due to a broad filter rule in RU AdList. This affects users with this filter list enabled in uBlock Origin.
Blocked Resources:
https://translate.brave.com/static/v1/js/element/main.jshttps://translate.brave.com/static/v1/css/translateelement.css
Blocking Rule:
$third-party,xmlhttprequest,domain=anisima.ru|arablionz.tv|artrozamnet.ru|...|diakov.net|...
Workaround: Adding @@||translate.brave.com^ to custom filters fixes it.
Filter List Response
I reported this to RU AdList maintainers (Issue #770). They declined to add an exception, stating they believe this should be addressed on the browser side rather than in filter lists.
Request
Could the Brave team provide guidance on:
- How filter lists should handle Brave’s translation service
- Whether there’s a standard approach for this across filter lists
- If Brave plans to work with major filter list maintainers on this
Users shouldn’t have to choose between comprehensive ad blocking and using Brave’s translation feature.
