Description:
When using Brave’s built-in Translate feature to translate a page into Persian (Farsi) or Arabic, the translated text is displayed with incorrect text direction (LTR instead of RTL). This causes the layout to become messy, sentences appear jumbled, and the reading experience is broken.
Microsoft Edge handles the same translation correctly and properly applies RTL direction.
Steps to reproduce:
- Open any English webpage.
- Use Brave Translate and select Persian (or Arabic) as the target language.
- Observe that the translated text remains left-to-right and the layout is broken.
Expected behavior:
The page should correctly switch to dir=“rtl” and display the text right-to-left after translation to Persian/Arabic.
Actual behavior:
Text direction stays LTR, causing poorly formatted and hard-to-read content.
Additional info:
- This issue has been reported before regarding Arabic RTL support.
- Brave Translate uses Lingvanex engine.
- The problem does not occur in Microsoft Edge (which uses Microsoft Translator).
Thank you for looking into this. Proper RTL support would greatly improve the experience for Persian and Arabic users.
