Brave to use specific network interface
There should be an option to select the network connection to the internet. a lot of pcs are coming out with more than one built in network card and that is including wireless. an example would be i have my router setup with a vlan built in vpn and would like Brave to be on that vlan. without having to have a separate application (vpn application/split tunneling) on my system to force Brave to use that application.
an application that has this feature that i can think of is qbittorrent with a binding method.
below link to the website on how to bind and a screen shot of their interface.
Screenshot_20251227_185649
i did submit a update request for os level similar on how we can select graphics cards to both linux fedora and KDE. hoping they can add it system wide. but it seems this can be done via the application layer since qbittorrent has done it. this would be a great feature add on.
