Brave sync has been unreliable for normal use for years for me
I have been using Brave for years now, and I’ve been using the Sync features for years. The reliability of this feature has never improved, but has likely actively gotten worse over time. I manage my bookmarks very heavily and desire to have my settings and extensions be consistent across devices, so I notice these issues with Sync constantly.
It doesn’t seem to matter what devices I have on my Sync chain or which started it. Devices forget they’re part of a sync chain constantly, and I have to constantly re-generate Sync codes for those, sometimes a Sync code I made within 5 minutes says it’s expired when I enter it on another device.
Within the last month, again the device I know 100% for sure I started a Sync chain on is no longer a part of any Sync chain, for no apparent reason.
I often notice drift between my devices’ supposedly synced items, and so once I go to check their Sync settings, they at least one or all are no longer part of a Sync chain. It then is a hassle to set them back up, as a new Sync code might not even get accepted by one of my devices after starting a new chain.
I am not doing anything strange with how I update Brave, not doing manually uninstalls/reinstalls myself and allowing the normal update processes to take place. It doesn’t matter if I’ve started the Sync chain on mobile iOS, Linux desktop, or macOS.
At least once a month.
Every version for several years
  • Arch Linux PC
  • iPhone (iOS)
  • macOS
I only sync the following:
  • Bookmarks
  • Settings
  • Extensions
  • Theme
