Brave shield does not block website blacklisted in Badware risks filter
Description of the issue: Brave Shield contains the “uBlock filters – Badware risks” filter. However, Brave does not block certain websites which are blacklisted by this filter. For example - “z-lib.id”, a phishing/scam website is a part of the Badware risks filter list. Any other browser paired with uBlock Origin is able to block this website from loading. However, Brave does not block this website. I have tried this with the “Trackers & Ad-blocking” set to Aggressive, but I’m getting the same result i.e., the website just loads.
Exact URL of the website in question: https://z-lib.id/
Screenshot of the ad as it appears in Brave: N/A
Did the issue present with default Shields settings? Yes
Does the site function as expected when Shields are turned off? N/A
Does the ad appear when using a Private window as well? (yes/no) N/A
What OS are you using when you see the ad?: Windows
Brave version (check About Brave): Version 1.78.102
