Brave Search flags my connection as Tor/VPN even though I'm using neither
I’m getting blocked when using the default Brave Search from the address bar, with this message:
“Your request has been refused by the server. If you are accessing this page from Tor, try changing the exit node. If you are accessing this page from a popular VPN service, try to switch to a different server or region.”
This happens on every search, even random words like “potato” which is not tied to any specific site.
What I’ve already ruled out:
  • No Tor window open, no VPN extension, no VPN software installed
  • Windows proxy settings are off (both automatic detect and manual proxy)
  • Secure DNS setting doesn’t fix it
  • Works fine on the same Wi-Fi in Microsoft Edge
  • Works fine on Brave when switched to mobile hotspot/data
  • Works fine in Brave once I changed my default search engine from Brave Search to Google
Brave 1.93.129 (Official Build) (64-bit)
Chromium: 151.0.7922.71
Operating System:
Windows 11 Home
