I am trying to connect Brave Rewards to my self-custody Brave Wallet on Solana, but although Brave Wallet is already set as my default Solana wallet in brave://settings/web3, the connection process repeatedly shows “Set Brave Wallet as your default wallet to proceed” and loops without reaching the Solana address selection step; I am using Windows 11 with Brave 1.95.102 (64-bit), my wallet is self-custody Brave Wallet (Solana), and I am in India, which is a supported region.
Hello, @Shashank_Mahato if you are tryuing to earn rewards, well all i can say is… ![]()
Hello @Shashank_Mahato if you did not get my previous message, then all i have to say is … well,
good Luck. ![]()
Having the exact issue here @Shashank_Mahato
Having the same issue, can’t seem to find a solution for it
In Canada.
If you clear your cookies and site data and try again do you still see this issue? Thanks!
