I have had Brave reset to default, with no clue as to why. In the previous post, I was ultimately informed "I am very sorry for your situation, however, it isn’t really ideal to run
Portable (more variables to go wrong)"
It happened again yesterday. However, for the first time, I discovered why
I’m curious why nobody ever mentioned this before in my past inquiries?
I have no idea why this happened. I even had a backup on another disc, but that one also was reset. I had also backed up the appdata folder. I hoped that replacing it might help, but no.
I there any was to disable this feature? All that work and info down the drain
This notification is coming from a Chromium feature/mechanism called the "tracked preference (or “preference hash”) system. In [very] short – Chromium places certain sensitive browser settings on a protected list that Chromium validates. There are a variety of settings included on this list, but both extensions and pinned tabs (shown in your screenshot) are among them.
So what’s happening is that the stored state of these settings in the browser is failing this validation and subsequently the stored value is rejected and resets the affected preference to a safe (or default) value. This is especially pertinent for extensions, as they are typically given a great deal of control over the browser.
Lots of things can cause this, but based on your post and other threads you’ve created, the most likely explanation here is your use of backed-up/restored states, as well as manually replacing browser/AppData files when updating. Inadvertently mixing older sets of profile/config files with new browser files can cause the integrity information/preferences themselves to no longer match.
So, somewhat ironically, the backup/restore process you’re [understandably] using to maintain your data may in and of itself be causing this integrity check to fail.
AFAIK there is no way to disable this (as it is an important security mechanism). The best way to avoid encountering it is by updating Brave normally (through the browser itself or by running the installer) and avoid manually replacing/restoring individual user data files. Backing up the profile is fine but restoring an old copy of the profile – especially across different Brave versions/builds – can put the preference data (and associated integrity information) out of sync and trigger this reset.
I’m not “mixing” up anything, unless we’re talking about trying to restore things after the wipeout. I backup the data/install folder, and I just mentioned the appdata backup (done right before the upgrade) because I was trying to avoid suddenly losing everything. Everything was working fine, until it wasn’t.
Right – but in doing this, you’re increasing the likelihood of the integrity check failing.
The application files your’e replacing and the User data files that contain the relevant preferences stored in your browser are stored in separate places and, given this, they are in separate pieces of “state”. Your existing profile data holds the “tracked-preference” values (and their associated integrity information).
When you update Brave (or any [Chromium-based] browser) normally, the update process handles an app update while also preserving and migrating it’s associated profiles as necessary. By manually replacing he entire application directory with a different build, you’re bypassing that normal update path. By itself, this isn’t necessarily a “problem” but, as I said before, it does increase the possibility of the browser’s stored preference state/integrity information getting out of sync – especially when you combine it with the backup/restore operations you mentioned previously.
TL;DR – Your method of updating isn’t necessarily the direct cause of the issue, but manually replacing app files and separately maintaining/restoring profile state you’re creating conditions in which the “tracked-preference” state can become inconsistent.
You should update the browser normally using Brave’s built-in updater function or running the installer to ensure this doesn’t happen. You can do this and continue to back up your profile data just in case anything happens to it.
Forgive me, but are you referring to my “portable” install?
Please correct me if I’m wrong, but these instructions do not appear to be for for a “portable” setup. There is no “built-in updater function” for a portable. No “installer”.
That BraveSoftware folder is where the “User Data” resides. That remained intact. Not altered inn any way.
I’ve never had this issue with any other portable setup. How else would a user update a portable install than as I described? That the advice I was seeking in the the previous post.
