toyman
1
Brave opens and then closes after 15 seconds. I have added the --disable-extensions
I just open it, then it closes 15 seconds later
Every time. I have used IObit uninstaller
Brave Version(about:brave):
latest download today
yes
It is best to uninstall Brave and install Brave again.
Important: when uninstalling you will lose all your browsing data.
Before uninstalling: Restart your computer
When uninstalling make sure that you check Also delete your browsing data?
When installing: Use the latest version of Brave (https://brave.com/)
system
Closed
3
