Brave on my honor magic 8 pro instantly crashes
No matter which way I open the browser, it crashes instantly. Animation plays but no page is open, it almost looks like I’m minimizing it to the desktop. I tried cleaning data, reinstalling, using beta and nightly versions, previous versions, changing WebView versions. Nothing helps or changes it in any way. Automatic battery management, power management is turned off. Other chromium based browsers run, chrome for example.
  1. It happened in a middle of the day. If it was because of an update, it must’ve Benn in the background.
  2. At first I was certain my screen was wet or I kept pressing minimize button accidentally, something wron with the screen. But everything else was fine.
  3. No idea how to reproduce it, I just open it and it closes instantly. No message. It still appears as running in the background, and it has a tab, but it won’t open for more than a split second, even from floating view, or opening outside links.
Brave Version( check About Brave): current, beta and nightly
Mobile Device details Honor Magic 8 pro
Hi,
If your display is set to a low resolution, switch it to inteeligent resolution.
Z.
It was screen resolution all that time​:sob:
